Airliner ( and other `planes ) design
shutter
Fixes: 47
I have a "mild" interest in aircraft, .... today I saw a pic of a Korean Cargo Plane landing at Schipol Airport.
EDIT EDIT EDIT..... ADD IN CORRECT PHOTO ! ! ! doh ! !...
http://www.jetphotos.net/photo/8277657
which made me think  "why did they put the flight deck so far back, giving the pilots a reduced "close up" view of the ground due to the "big nose" area infront and below the line of sight....  I have been told that pilots often cannot see the ground less than 5 miles in front of them at 2, 000 feet... !... must be really difficult to land a plane with that reduced vision area...
However,... I then saw this pic...
http://www.jetphotos.net/photo/8261131
And thought that was  a much better design... however, again, the forward and below vision will still be restricted, though, less so...
Perhaps it goes back to the days of two seater aircraft, where the pilot sat in the rear seat   ? ? ? ? ?  how weird... and the passenger sat in the front seat....
7 REPLIES 7
AlaricAdair
Re: Airliner ( and other `planes ) design
Did you pick the right photo? Looks just like a standard airliner to me.
Now Zen, but a +Net residue.
shutter
Fixes: 47
Oops... seems to have lost the Korean Cargo Plane... so have edited it back in ...... Thanks ! ! ..
spraxyt
Fixes: 75
Pilots are very adept at looking forward and downwards over the side of the cockpit to view the approaching ground. It was like this in tail-draggers of old too.
David
PowerLee
The 747 cockpit is there due to a quirk in the design, as part of the cargo conversion there would be a large opening nose section that allows access for easy cargo loading / unloading.
Remember the 747 was originally designed as a military prototype cargo carry transport aircraft.
PeterLoftus
On some recent flights I have been on there has been TV cameras available to the passengers over the entertainment system. One of these was the view forward and I have used it when landing. Quiet entertaining Smiley
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Mal08
If you look carefully - you can see the line where the nose door is - it goes down from near the cockpit to a point midway between the nosewheel and the very front of the nose.
When the 747 first came out the extra height off the ground was one of the issues that needed extra care.
rongtw
Fixes: 12
Shutter this is one site i aquire some photos from  search is good on web page
http://www.airliners.net/
