Air Filter
Fixes: 15
Air Filter
Anyone use or have used K&N air filters ?
The claim is that they increase mpg which could be true as the filter is not enclosed in a housing like the standard filter.
NB: I promise not to ask further questions about cars for the next few months in case I am accused of turning the forum into a motoring forum.
Smiley
12 REPLIES 12
Re: Air Filter
They also claim to increase prformance; increased performance, less mpg. Simples.
Re: Air Filter
K&N cone filters or K&N replacement filter elements?
People fit cone filters because they assume that having a filter bolted directly to the throttle body inside a hot engine bay filled with hot air from the hot engine means they now have a "cold air intake", when the vehicle's stock airflow system is more of a cold air intake than the silly cone things, and as a result, the air under the bonnet is less dense, so reduces power, makes you burn more fuel, and drops your MPGs because you're getting a weaker fuel-air mix (as modern cars with MAF sensors will reduce the fuel injected into the cylinders to match the incoming volume of air), so, waste of time, money, paper and petrol...
As for the replacement elements (ones that sit in your vehicle-stock air filter box), I hear good things about them, as you can clean and "re-charge" them rather than just buy one, fit one, bin one, etc., which makes it somewhat greener, not by much, but, just enough... Smiley
Fixes: 44
Re: Air Filter
Any reputable replacement make of Air Filter Element,  WILL Increase the M.P.G. when it is first fitted... after about a month, the difference will be less, as the filter becomes dirty, and has to "work harder" to clean the air provided to the engine.  Just because it has that claim on the box, doesn`t mean it will be more efficient over the life of the filter..  just that for the first few weeks, you "could" claim that it does, indeed increase the M.P.G.
Read the description carefuelly !  ! ! ..Cheesy
Fixes: 21
Re: Air Filter
I've used a K&N on my bike, a lifetime filter, just clean it in petrol and put it back in.
I had a SS one on a Mini about 30 ish years ago. Made a great noise when you put the foot down (1275gt)
Re: Air Filter
Fixes: 44
Re: Air Filter
I had a couple of SS/Chromed round filters on my 1200cc Triumph Herald... ( modified the exhaust by using a Spitfire manifold, and twin carbs)... all parts of engine bay pristine, clean, repainted, shiny brass top on radiator, two shiny filters...)
Used to love opening the bonnet at a petrol station , to check the oil, and water... ( not that it needed it  ! ! ! ! ! !)..
Re: Air Filter
Fuel-injected engines will never have their fuel consumption improved by fitting one of these because the ECU works out perfect fuel/air ratio based on the air flow, so even if the air flow increases, the fuel/air ratio will also change to suit. Carburetted engines will probably see an improvement.
Fixes: 14
Re: Air Filter
Doesn't worry me glen, we've had plenty of motoring topics in the past and I suspect there will be plenty in the future - it's a general chat forum, anything goes!
Quite frankly, it's just nice to see some activity here.
Re: Air Filter
Best thing I remember about the good old Herald was the turning circle. Most roads a one point turn was a doddle.
Friend had a Vitesse which was a good model to do up. Nice to drive once you fix the "pop up" suspension.
Fixes: 15
Re: Air Filter
@nozzer wrote:
@gleneagles
You might find this interesting!
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
Thanks for the link, some interesting  data in that report.
@7up,
Thanks for the response, one of the key factors in Chat is the variety of topics that come up for discussion, which keeps a larger group of people willing to post topics & replies.
As you say it can get a bit quiet at times but equally I don't want to be seen,'hogging' the forum with new posts or responses.
SmileySmiley
Fixes: 44
Re: Air Filter
Yes, indeedy... I had a Vitesse 2ltr..... grossly overpowered... but a super car to burn the other guys off the road... ( they thought it was just a triumph herald.... until they noticed the chrome bumber and number plate lights with the word VITESSSE and 2LTR stuck on the boot ! ! ! hee hee  )
Used to remove the roof on sunny days... no. it wasn`t a convertible,... but only 6 bolts to undo and lift it off ! ! ..  (probably illegal, but it was great ! )...
Fixes: 12
Re: Air Filter
I had a 1972 series 3 landy Smiley  it ran a lot better with a K&N Thumbs_Up
sold it a few years back ,, i do miss it
