Advice please
Fixes: 9
Advice please
We got a circular the other day to inform us a saving of 10- 20% could be made on our water Bill irrespective of having a water meter fitted.
A Website does exist,
http://www.smartsourcewater.co.uk/
Would be grateful for any comments anyone has about this as I always thought that unlike Gas & Electricity you could only have one supplier of water ?
pierre_pierre
Re: Advice please
look at some of the reviews on the RH side, just looked at the BBC one
they make  the saving by making sure you dont pay fro rain water drainage, dont know where you live, but as our road had gutters and drainage, we had to pay, I did look into it
As we live in the driest part of the UK I have a collection on tubs and not much of my roof water does go down the rain drain (it is separate to the foul water)
Fixes: 15
Re: Advice please
In the Portsmouth area, you get two water bills... one from the "supplier".... and the other from the company that deals with the drainage !....  (Southern Water, and Portsmouth Water Company).
Normally these two functions are performed by the same company, hence only one bill...
