Advertising "con" ? ? ?
Fixes: 13
Keep an eye on the SKY HD advert on the tele.....
It says that you get  a FREE sky hd box when you sign up.... ERM !! ? ?
Presumably you can go down to currys or PCworld and buy one without having to sign up then......?
Fixes: 126
Re: Advertising "con" ? ? ?
deleted because I can't read...
However... Shutter yes you can, for lots of money, but you'd be better of getting a freesat as I don't think you can access the HD channels without a HD pack.
Will Moderate For Thanks
Fixes: 16
Tesco had them on the shelve for about £200, not sure if they are still there .. not been in that area for a while.
But I have been told that if you buy one you still cant access the FREE HD channels, only the SKY PAY ones which seems a waste of time for me anyway.
pierre_pierre
not sure about the Sky HD but the standard Sky can access the freesat ones via the manual extra settings, thus if you live in Essex, you can watch the Scottish Folk programs
Fixes: 58
but why would you want to unless you like to see hairy men prancing about in skirts  Lips are sealed
Fixes: 13
Och, it`s cheaper than mooooving house, d`ya ken !....
