Adblock totals
Adblock totals
My adblock reports it has suppressed 150093 adverts on my Chrome browser since I installed it.  The inventors deserve a medal.
Now Zen, but a +Net residue.
Fixes: 388
Re: Adblock totals
I'm at 547095!
My Broadband Ping - PN-Fibre
Fixes: 21
Re: Adblock totals
I`m on Firefox.... can`t seem to find the total....only reports "issues on this page"  plus a few disable requests....
where do I find those stats?
Fixes: 388
Re: Adblock totals
click the button and i see
Fixes: 21
Re: Adblock totals
Hmmm.... I`m on Adblock Plus... and it is minus a lot of those !.....
I get....
Report an issue on this page
open blockable items
Filter preferences
disable on community plusnet
disable on this page only
disable everywhere
and
Options
and there is nowt in the options for displaying the results,    only for "resetting" them.... !
( my adblock icon is not a "hand"  just ABP in the octagon )
Re: Adblock totals
I have Chrome and Firefox. I have the same problems opportunities as you on Firefox.
2u2me
Re: Adblock totals
Fixes: 188
Re: Adblock totals
I appear to have Adblock Plus 2.6.6 and get the same as Shutter Undecided
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Fixes: 21
Re: Adblock totals
I got adblock plus, because I thought it was a later version of adblock.... so i wuz conned !...  Sad Sad
it seems to have less rather than plus ...  might just go and change it !>.. Cheesy
Fixes: 38
Re: Adblock totals
I too was running ADP but on reading 2u2me's link I uninstalled and installed AdBlock and already my counter is at 96!
RPMozley
Fixes: 5
Re: Adblock totals
So you're changing it simply for a total? There is actually a total available in ABP but is somewhat hidden away, specifically on the filter options window (it was there the last time I looked, which was a little while ago). Huh
That's RPM to you!!
Fixes: 38
Re: Adblock totals
No, not at all, totals are of no interest to me. I changed it as like others I assumed it was the 'GT' version of AdBlock.
RPMozley
Fixes: 5
Re: Adblock totals
Oh, ok. Just seemed like that was important with the way it was mentioned in your post. Sorry.
That's RPM to you!!
Fixes: 62
Re: Adblock totals
This is almost certainly biased BUT READ IT https://palant.de/2014/07/29/which-is-better-adblock-or-adblock-plus
RPMozley
Fixes: 5
Re: Adblock totals
To also add further to the mix, there is a fork project off of ABP called ABP Edge where they removed all the "sponsored ads" and kept to the original ethos of ABP. It's currently only available as a Firefox add-on.
That's RPM to you!!
