Ad music?
Ad music?
Anyone know what the music is in the current Argos ad. Its a very light classical "lollipop".
zedingrove
Re: Ad music?
Play it to google....
Re: Ad music?
Is it this one?
Call me 'w23'
Re: Ad music?
Thank you walker23 yes.
A long time ago I used to have an LP (remember those) called "Classical Lollipops" if I recall it was a  Readers Digest compilation, this was one of the tracks along with a whole host of similar "fun" classics. Very enjoyable.
Have occasionally looked around for something similar without much luck.
