Ad blocking
petlew
Ad blocking
With reference to the moved post "New Member".
I guess there's some obscure technical reason, but why should we have to switch off Ad Block software to use the PN customer service chat.
I use chat service's with other companies, PN seems to be the only one (that I use) that requires this, some advise it but don't actually stop you using their chat if you don't, my online banking being a case in point.
1 REPLY 1
shutter
Fixes: 47
Re: Ad blocking
Many people do not know some software they are using, or add-on they are using, comes under the "generic term"     ... [adblocker]   and without any specific software name/add-on name, haven`t a clue what to do about it...
To save the hassle, I have got OPERA installed, and also WATERFOX, which I use (almost) exclusively to access "Live Chat" with PN...don`t have any "addons" with them.... just use them "as is" after install....
