Ad Solitaire
Ad Solitaire
Occasionally while waiting for my next coach load of students to be released from school, I will have a quiet game of Solitaire on my iPhone.
But I do sometimes get exasperated with the sometimes multi-screen adverts between each game. Getting worse than Channel 4 ad breaks, I've looked but can't see any setting change that will turn them off.
Anyone know if the ads can be turned off?
Fixes: 229
Re: Ad Solitaire
As far as I know (not sure with your particular game) the only way is to purchase it rather than use the free version. Personally I can get along with the adds as the are not intrusive in the games I play even on my phone.
Forum Moderator and Customer
Fixes: 6
Re: Ad Solitaire
It's probably got an in-app purchase which might turn them off - with a bit of luck it won't be that much.
Worth it if so, they're annoying you, and you use it often.
I've got a paid for version which didn't cost me much - something like 75p or £1.50, can't remember now.
Personally, I really fucking hate ads.
Re: Ad Solitaire
Buy the game, then you won't have ads... Roll eyes
