AR put-downs
AR put-downs
I realise that Ann Robinson has her between the rounds of the Weakest Link put-downs written for her by an army of "researchers" or are sent in by viewers, there's a certain amount of repetition and some are just plain naff but just occasionally she gets some amusing ones:
"who's been brainwashed...and it shrunk"
1 REPLY
Fixes: 19
Re: AR put-downs
Quote from: Petlew
She is quite self-opinionated, then.. Grin Grin Grin
