A shot in the dark
Minivanman
Aspiring Legend
A shot in the dark
A shot in the dark, but has anybody here tried replacing the grill thermostat on a Rangmaster 90 cooker?
Ours will not stay alight once the knob is released so I guess that's the problem on what is now a ten year old cooker, but for the life of me I cannot figure out how to access it.
Done the usual YouTube/internet search but nothing found so far. Sad
Don't limit the friends you haven't met with arguments you'll never have.
7 REPLIES 7
Re: A shot in the dark
Is this any use you @Minivanman
shutter
Fixes: 47
Looks like a GAS cooker.... ?   in which case it may be the "thermocouple" device that is not functioning correctly.... this is a small probe that sits within the flame area..... i think that it needs the flame heat to keep the gas valve open to maintain the flame on the relevant item... e.g. your grill... or the gas hob(s)
Minivanman
Aspiring Legend
@Anonymous
Cheers, that might just do it.
Will have a little read through as I watch Wales beat Ireland Wink
Minivanman
Aspiring Legend
@shutter
It is a gas cooker, and the thermocouple enters from the right hand side of the grill but at this stage I cannot figure out how/or what panel to take off in order to change it.
Easy when you know how, as with most thing. Roll_eyes
billnotben
Sometimes it's just the flame/pilot whatever that's slightly blocked or not quite pointing the right way.
Sometimes a good clean and a wiggle in the pilot hole is all that's needed. And if possible you can always point a gas lighter at the thermo thingummy to check if it works when heated up.
Minivanman
Aspiring Legend
@billnotben
Good point Wink
The gas lights every time but worth checking the thermo thingummy as you say and apparently, they can also get covered in muck or whatever from all that cooking residue so it might be worth giving it a gentle wipe with some light abrasive.
shutter
Fixes: 47
a toothbrush dipped in washing up liquid.... then rinsed off with a clean  toothbrush dipped in water, If accessible,..then dry off with kitchen towel..
