A "Must Have" alternative to the PlusNet Mug !
Fixes: 16
Steve
Seasoned Pro
Re: A "Must Have" alternative to the PlusNet Mug !
That's just wrong. Sad
If life gives you lemons, make lemonade.
Another good one Shutter Smiley
Fixes: 81
Ordered Embarrassed Grin
Customer and Forum Moderator.
pierre_pierre
pierre_pierre
pierre_pierre
Gironic aint it
Noticed that "shutters" mug is available new or used...
Uhmmm!!
avalon
The used one probably comes with cocoa stains inside. Grin
Fixes: 81
Quote from: Strat
My 'mug' arrived this morning and I have just had my first cup of tea in it.
It's brilliant...I love it. The cistern gets in the way a little but apart from that I love it. Cheesy
Were you flushed with excitement when it arrived Wink Wink
Fixes: 81
Absolutely.
I was so excited I had to sit down for a while Wink
Was it one of the new or used ones?...were there any unidentified stains?
Fixes: 81
Brand spanking new....thank goodness Lips are sealed
Can't get the seat up though Embarrassed
Probably mentally unhinged
