A neat little trick.....
Aspiring Legend
.......and one not seen before.
It's a 2-gang moulded converter switch.
For some reason unknown to myself (I was probably in a hurry) I only put a single wall plug in the spare bedroom and just enough for a reading lamp - or so I thought. Now of course the grand-kids want to be able to plug in their smart phones and whatnot so rather than an adaptor I just changed it for this.
Fits well enough and secure even on a cavity wall in a little used room.
PS. Another neat item was this little gadget, a double usb charger with plug surge socket which also doubles as a neat little night light. Gotta keep the kids happy Smiley
Compare yourself to who you were yesterday, not who somebody else is today
11 REPLIES 11
Fixes: 5
Re: A neat little trick.....
Most standard 2-gang surface-mount pattress boxes have a set of holes in the back which are spaced at the same distance as that between the 2 mounting holes on single-gang back boxes, so you don't actually need a special converter to do the job.  Wink
Aspiring Legend
Never noted that @RobPN
Have a few spare doubles and can see no holes at the same distance. Interesting.
Can you post a picture? Thumbs_Up
Fixes: 5
I'll see if I've got any spares out in the garage tomorrow. Wink
The holes I'm referring to are of the type intended for countersunk-head type screws and there are usually 4 of them arranged in approximately a 'southern cross' type pattern so the 2-gang pattress could be mounted horizontally or vertically over a single-gang back box.
Just had a quick search online to save me looking tomorrow and came across this example
Maybe I should have said 'many' instead of 'most', although I think most of the ones I've used (although that's not that many) in the last few years have had those holes as described. Smiley
Aspiring Legend
@RobPN
Thanks, and never knew that.
Old dogs and new tricks eh Smiley
Aspiring Hero
Fixes: 50
They'll be thinking of sliced bread next.
Ex-Plusnetter now living life in the G,fast lane!
And here's me using BS546 still... Funny
Aspiring Legend
And still available from the likes of Amazon Cool_smiley
Most likely due to the fact that theatres still use the 5A and 15A plugs for the lighting rigs, aswell as there being plenty of foreign sources of them given India and South Africa still use them too (ex-colonies after all!), but BS546 is handy, wire up your power tools with the plugs and it stops people borrowing them... Funny
Aspiring Legend
@RobPN
The couple I have found in my shed have not got those extra holes Rob but even so, not sure if they would be strong or robust enough to withstand much use - although I'll admit the converter I have now fitted could be better but as said, it's only for the spare bedroom so it'll get little use.
Something to watch out for in the future anyways so thanks for the tip. Thumbs_Up
Fixes: 5
@Minivanman wrote:
... couple I have found in my shed have not got those extra holes Rob but even so, not sure if they would be strong or robust enough to withstand much use - although I'll admit the converter I have now fitted could be better but as said, it's only for the spare bedroom so it'll get little use.
Although the holes under discussion are conveniently placed there's nothing to stop the holes at the ends/corners being used in addition or instead of (if you wish to mount one over a single-gang sunk back box).  Wink
Aspiring Legend
True Thumbs_Up
