A good read (if you like this sort of thing)
I do...
Captain Grumpy's Book of the Road: and other infuriating stuff:
http://www.amazon.co.uk/Captain-Grumpys-Book-Road-infuriating/dp/1480163953/ref=sr_1_1?ie=UTF8&qid=1...
(sadly not available for Kindle)
Fixes: 188
Re: A good read (if you like this sort of thing)
it does look enjoyable but a sign of the times when if it's not available for my kindle I probably won't get it..
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Looks good, ordered from the mobile library, sometimes takes a month or so for books to arrive and I normally comment 'did I really order this' much to the amusement of the mobile librarian.
Fixes: 9
Think I will follow your lead and get it from the library !
