A Quick little no brainer quiz... Correct answer...
zedingrove
OK Question 1 0f 1. On average how long does it take CS to answer your call at... 10am - 3pm - 10pm and 3am
Will give you a clue as most of you doubt have called CS at 3am - average is 30 seconds....
Good Luck
Infinity
Seasoned Pro
Re: A Quick little no brainer quiz... Correct answer...
I rarely have to wait more than 5 seconds at 3am, after negotiating the menus, which I have on Speed dial.
Daytime, not much longer, except for outages, when PN are really busy.
James
10am - 18s
3pm - 1m41s
10pm - 1s
3am - 1m14 (this is actually the average from midnight to 7am)
All above are based on Tech yesterday, not specifically CSC.
Your average is entirely factually incorrect. Sorry Smiley
zedingrove
10am - 3 mins
3pm - 1.5 mins
10pm - Gave up as there were 4 in queue
3am - 22 seconds
Actually the average time using all three times is 33.6 seconds
James
I gave you the actual answers - not guess work.
MJN
You're both right; and it is an illustrative example of the effects of different sample sizes...   Wink
James
Quite Smiley
