When you call 999, an operator asks which emergency service you require before rerouting the call to the police, ambulance service or fire brigade.
In certain situations, it may not be safe to make a noise – for example it could alert a potential attacker to your exact whereabouts.
You simply dial 55.
The procedure is called Silent Solutions and it was created so people in an emergency can call the police in dangerous situations.
After you dial 999 and you’ve been unable to audibly signal to the operator, your call will be forwarded to an operating system.
If you’re in danger, dial 55 otherwise the call will be terminated.
The ‘55’ Silent Solution protocol has been in place for over a decade, although police have recently issued a reminder as not many people know about the protocol.
10 REPLIES 10
Browni
Aspiring Hero
Fixes: 52
Re: 999 - 55
 Hopefully not Windows Vista...
I'll get my coat Smiley
Ex-Plusnetter now living life in the G,fast lane!
nozzer
Re: 999 - 55
@Anonymous
Not quite correct! If the operator doesn't hear an immediate voice, in other words there's total silence, you will be prompted to tap the handset, cough or make some sort of noise. At this point the operator will put the call through to the 55 service and you will be prompted to dial 55. The call can then be traced.
Minivanman
Aspiring Legend
Re: 999 - 55
Or, you could just send a text.
Just saying.
Don't limit the friends you haven't met with arguments you'll never have.
nozzer
Re: 999 - 55
You might mistype "help" in your mad panic. They wouldn't know what "ndlo" meant! Think about it. Wink
You make a good point actually. I got my mobile registered just in case for when we're out in the wilds with not much of a phone signal.
http://www.emergencysms.org.uk/
The way this works is that your phone will look for any mobile signal, not just your own provider's, in the same way that a 999 call does. And because the text data content is tiny it stands a good chance of getting through when it catches a signal. Many a mountain walker has been helped by this.
Jonpe
Fixes: 9
Re: 999 - 55
@nozzer  I thought they could trace your call regardless of whether you spoke, coughed etc.
198kHz
Fixes: 32
Re: 999 - 55
@Jonpe  Yes, it can be. The point is that with so many accidental/malicious silent calls, without the 55 it probably won't be.
A journey of a thousand sites begins with a single click.
ADSL2+   Billion 7800N
Jonpe
Fixes: 9
Re: 999 - 55
If the system is operated by BT they'd probably send the coastguard to someone calling from Leicester if no specific service is requested.
chenks76
Fixes: 12
Re: 999 - 55
although it does say "the service is for people who cannot make voice calls because they have a hearing loss or a speech impairment."
not for anyeone that just finds a need to send an SMS.
Strat
Fixes: 514
Re: 999 - 55
Preferably 3 short taps followed by 3 long taps followed by 3 short taps.
Customer and Forum Moderator. Windows 10 Firefox 89.0.1 (64-bit)
nozzer
Re: 999 - 55
@chenks76
Although the web site does say that, the facility is also promoted widely by walking and mountaineering organisations and has been used successfully on many occasions by that group of people. I don't think anyone objects to them using it under the right circumstances.
