4 wheels (not) on my wagon
x47c
This is cracking.......
Why they continued to the gate is a mystery - yes get it off the runway OK but you would have thought they might have stopped at that point.
Can you imagine the conversation in the cockpit - mmmmm, yes it does pull to the right a bit doesn't it.
http://avherald.com/h?article=47f968b7&opt=0
Fixes: 9
Re: 4 wheels (not) on my wagon
Interesting, I cannot play this video as the message appears to inform me that adobe plug in is not up to date,
If I try to update simply get the message from mozilla that the plugin is up to date ?
Anyone else have this problem ?
Firefox version 34
nope, but I'd received an upgrade earlier this morning.
Now Zen, but a +Net residue.
Playing OK with Firefox 34.0.5
How could the pilots not have known. Ground control must have been aware as well Undecided
Fixes: 251
Quote from: gleneagles
Firefox version 34
Often I get the message to update with another line underneath asking to activate.
If I click Activate then I get the option to activate this time only or every time (can't remember the exact wording).
Forum Moderator and Customer
x47c
More piccy's here - including damage to the underside of the wing.
Just a bit of polish and buff up should do it.............
http://forum.contatoradar.com.br/index.php/topic/113527-767-da-american-estoura-4-pneus-durante-pous...
They won't be using Quickfit again in a hurry ;-)
