3d artwork
Tyreal74
3d artwork
started learning 3d, heres some results - ya im bored
hourglass - first ever render
p38 work in progress
need to redo the spontoons for proportions
any other 3d modelers on here?
suesykes
Re: 3d artwork
Thats pretty good for a learner... I have mastered the sphere.
Check out here...
http://www.3dcafe.com/
Got some nice inspiration for ya if nowt else.
James
Re: 3d artwork
Those are really good for a first effort.
Tyreal74
Re: 3d artwork
upon revisiting the p38, i have found that there are some major errors in my model, thus im going to can the project and just continue with my tutorial pages - and for now the supplied files - checting i know
VileReynard
Seasoned Pro
Fixes: 10
Re: 3d artwork
Quote from: Tyreal74
Could you explain (for a non-artist) what is wrong apart from a few aliasing errors on the curves (if you look really closely)?
Tyreal74
Re: 3d artwork
its not anti aliased, its due to the low poly count.
the spontoons vertices towards the rear are off positoon along the y axis causing them to be thinner than they should be forcing the protrusion of the exhaust, the wings are fine apart from 2 vertices on the edges that are causing the 'lip' the gondala has 3 x vertices thats out of alignment so i cant cut the polygons to form the cockpit.
is how its meant to look from the tutorial
