2k
shutter
Fixes: 47
2k
Thanks.... for the Thanks... !
11 REPLIES 11
shutter
Fixes: 47
Re: 2k
Oi!  Who stole my thanks ?Undecided
4 hours ago.,... i posted a thanks for the thanks... as above..  it got an extra "thanks"... and then showed 2001  ......
now it`s showing only 1998 ....  Cry
Alex
Fixes: 12
Re: 2k
Well done @shutter
You should work for the goverment though, using reverse psychology to try and manipulate your figures. 😀
P.S. That is a joke, so no-one tell me off please.
RobPN
Fixes: 5
Re: 2k
@shutter
Perhaps someone (not me BTW) went back and ' unthanked' some posts just to mess with your numbers take the wind out of your sails.  Cheesy
Steve
Seasoned Pro
Re: 2k
Are they all ' thanks ' though or just the good old ' thumbs up ' ? Either way I don't have a cake big enough to fit that many candles on it 😜
If life gives you lemons, make lemonade.
7up
Fixes: 14
Re: 2k
I've accidentally thanked a few posts in the past without realising it (sometimes my finger twitches on the mouse button). When i realise what i've done i'll unthank it but i've not had to do that for several months.
RobPN
Fixes: 5
Re: 2k
It must be about 2-3 weeks ago that I noticed the little pop-up message that said a 'certain person' had thanked one of my posts.
"Strange" I thought to myself, not really bothered about receiving thanks from the person in question..
When I happened to check that particular thread a bit later there were no thanks on that post so clearly 'they' removed it, which suited me fine.
Jonpe
Fixes: 9
Re: 2k
It's showing 2682 now (11 hours after your post); at this rate you'll be a thanks millionaire by Christmas.
Alex
Fixes: 12
Re: 2k
Yep @7up
The thanks button is next to the reply button. Easy mistake to make.
Whoever at PlusNet decided to use the Lithium software and the developers themselves must have taken very some lunches (I suspect down the pub).
I wonder if Lithium or PlusNet have the mental capacity to fix the unread posts flag bug. Maybe within my life expectancy?
QA at PlusNet must have been down the pub as well to sign this off.
shutter
Fixes: 47
Re: 2k
Ah yes.... that `s the total for all boards... my 2k was referring to General Chat total ! .
TTman
Seasoned Champion
Re: 2k
@shutter should be back to 2k nowEvil
198kHz
Fixes: 32
Re: 2k
No disrespect to you @shutter, or anyone else, but I can't help thinking that a more meaningful metric would be, for example, nunber of likes/thanks as a percentage of total posts.
Warning: the Internet may contain traces of nuts
ADSL2+   Billion 7800N
