10m ethernet cable or RJ11?
NorthEasterner
Need to connect my TT Youview box to broadband.
I found a RJ11 10m for £2.20 off Amazon.
Or I can get a flat ethernet cable for £4.79.
Flat is preferred so I can't easily trip over.
Shall I get ethernet or RJ11?
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
Fixes: 186
Re: 10m ethernet cable or RJ11?
Perhaps you could ask on TT or your ISP forums, they might be able to advise you better as it's their products.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
pwatson
As it's Christmas...
You need an ethernet cable.  RJ11 cables are used for telephony, an ethernet cable uses RJ45 connectors.
NorthEasterner
Okay i'll get an ethernet cable.
This is not at home, in my cottage in Northumberland.
We have got TalkTalk installed and get a shocking 15meg dl speed.  With simplybroadband.
This cottage will be rented by other people as its a rental property owned by me and the family.
Devonian
So, you post on the Plusnet forum, you say your isp is BT (spit), and you are trying to connect a talktalk (vomit) youview box to the internet?
Wow sounds perfect to me.  Cheesy Cheesy
NorthEasterner
At least TalkTalk actually provide a better speed than I had with PN.  Why would I get PN if I don't actually live in the cottage full time and TT is cheaper.
Fixes: 10
Your choice of provider is not being questioned.
Your continual posting on the Plusnet forums requesting advice regarding your non-Plusnet connections is what people are concerned about.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
NorthEasterner
I find I get a better response from community members on Plusnet forums, than BT and TT forums.
This forum feels local and friendly so thats why I prefer to post here.
I can't see how this is affecting other people.  It's just a person asking for advice, nothing wrong with that is there?  Roll eyes
Fixes: 83
When resources are limited........ Lips are sealed
Customer and Forum Moderator.
RichAllen
Someone once told me the TT forum is full of idiots.
Fixes: 10
Quote from: Devonian
+1 lol
Quote from: RichAllen
You're so opinionated..
Unless it's changed radically since I was last there (admittedly a year or so now) it was seriously lacking in constructive help from the ISP itself and more time was spent hiding (even banning) problems than solving them.
NorthEasterner
Thats why I don't post on there.
Last time I started a post, I never got a straight answer
Back on subject, I doubt the overall area / diameter of a round RJ45 CAT5e cable is going to be significantly bigger than that of a flat ethernet cable - both should be just as easy to hide at the edge of skirting or tacked on the skirting board. I've run it previously between the carpet gripper and the skirting without a problem.
And yes, don't go for RJ11 cable - it tends to be straight wired rather than twisted pair and certainly won't conform to CAT5 standards your Youview box should need for an ethernet connection.
Quote from: NorthEasterner
Presumably, though you haven't said so explicitly, this is an Ethernet connection from the box to a router?
If you're up to terminating cables yourself and want something relatively unobtrusive, consider CW1308 4-core phone cable. This will run at up to 100mbps so is more than adequate.
