10 reg
petlew
10 reg
Having seen a couple of 10 reg cars in the last couple of days, made me wonder what happens in September this year, will it be 15? Thereafter to be 11 in 2011, if so then 15 will reappear in September 2011 and, what happens in 2015, when the logical sequence will be 50 followed by 55 in September 2015 which has already been used fairly recently.
Or is there a new sequence such as the September 2nd number being 6 instead of 5?
Or are we going to be encouraged to get rid of all of our existing older reg cars before that happens so that older registrations car be recycled?
4 REPLIES 4
artmo
Re: 10 reg
Maybe this will help:
Number Plates
petlew
Re: 10 reg
Gee thanks artmo!!
itsme
Re: 10 reg
and if you have not worked out a simple way to determine the year it's-
If <50 the 2 digits represent the year. eg AB 25 CDE is for year March 2025
If > 50 subtract 50 and the resultant 2 digits will give the year. e.g AB 75 CDE is for September 2025
Fastyam
Re: 10 reg
A good place to find help is here personalised number plates
