Lægen
1,2,3...
1) Smartphone blank screen, buttons do nothing... expensive ?
     Took out battery, put back in, rebooted.................. OK
2) Microwave, reheating batch cooked meal, door wouldn't lock shut... though still under warranty
     Shut door a few times, with door release button pressed, eventually came good.
3)  Tesco C&C order, for first time in weeks, had no Granary loaf.
       Attendee said was probably OOS at midnight when order fulfilled.
       Quick trip into store....... loads of Granary on shelves.
What's next ?
I'm staying in.... just in case.
5 REPLIES 5
198kHz
Fixes: 31
Re: 1,2,3...
I was always taught that these things come in threes, so you should OK for a while.  🤞
The older I get, the earlier it gets late.
ADSL2+   Billion 7800N
twocvbloke
Re: 1,2,3...
@Lægen wrote:
What's next ?
Nuclear war of course...
nozzer
Re: 1,2,3...
@twocvbloke
Wee Donny in the US is working on that one to foil Biden.
Lægen
Re: 1,2,3...
@Lægen wrote:
What's next ?
4) Today, as for the past few days, the main Ctrl key on my computer was playing up....
      I use it several times a day to shortcut key enter date in Excel.
I should have remembered the KISS principle.....
I spent ages on the web with Google searching for reasons......
Some software glitch ?
Even removed the key and cleaned location, still not working.
Then I remembered, as you do, I had another similar keyboard in a cupboard, along with a couple of touch bluetooth mini ones, which I don't like using.
So.... swapped keyboards.... result, all functions restored !
Would have only taken a few minutes to sort !
Replacement OEM keyboard is £120+
And I still have two bluetooth keyboards for the future.
I did buy a spare keyboard a few years back, £20 then.....
(The RH Ctrl key worked fine, just not used to using it)
So, roll on 5)...
198kHz
Fixes: 31
Re: 1,2,3...
Eternal optimist, eh?  😃
