markroxxy123
0114 2999417
Can anyone tell me if 0114 2999417 is a genuine plusnet number? It keeps calling but when I answer there is no one at the other end of the line. An internet search suggests it is linked to plusnet, but can anyone confirm this?
Mark
6 REPLIES 6
Fixes: 73
Re: 0114 2999417
Looks to be John Lewis Broadband, supplied via Plusnet. Are you with them, or have you visited their site for any reason?
198kHz
Fixes: 31
Re: 0114 2999417
Voice Marketing Ltd
The Mount
Broomhill
Sheffield
S10 3FL
0114 321 0000
https://www.voicegroup.co.ukOpens a new window
Numbers that might be used to call you:
If you're a Plusnet Home Broadband or Mobile customer.
0114 299 9417
If you're a Plusnet Business Broadband customer.
0345 112 6604
https://www.plus.net/about-us/people-we-work-with/
The older I get, the earlier it gets late.
ADSL2+   Billion 7800N
shutter
Fixes: 47
Re: 0114 2999417
You can find out a lot about suspicious phone numbers from this site...https://who-called.co.uk
If you put the number in, it will show up comments from others who have had calls..
it seems to be a genuine Plusnet number as there are reports about them checking to see if the order has been completed....
markroxxy123
Re: 0114 2999417
Thanks for the replies.
Is it possible to block the number? As no one is on the other end when I answer it is getting annoying
Fixes: 73
Re: 0114 2999417
@markroxxy123 Yes you can block it without any real detriment. As to how, that depends on you home phone set-up.
markroxxy123
Re: 0114 2999417
Thanks, using the free 1572 service I have blocked the number.
