xe-10-2-0.pcl-cr01.plus.net [212.159.0.200] - RTT nearer eme than 40ms
Gythral8PNC
Target Name: N/A
        IP: 159.100.232.171
  Date/Time: 01/11/2014 21:50:40 to 01/11/2014 22:03:25
Hop Sent Err  PL% Min Max Avg  Host Name / [IP]
1    52  0  0.0  0  1  0  dsldevice.lan [192.168.1.254]
2    52  0  0.0  46  80  49  lo0-central10.pcl-ag03.plus.net [195.166.128.184]
3    52  0  0.0  46  48  46  link-a-central10.pcl-gw01.plus.net [212.159.2.168]
4    52  0  0.0  45 175  54  xe-10-2-0.pcl-cr01.plus.net [212.159.0.200]
5    52  0  0.0  46  89  48  xe-11-2-0.edge3.London2.Level3.net [212.187.201.213]
6    52  52 100.0  0  0  0  [-]
7    52  52 100.0  0  0  0  [-]
8    52  0  0.0  55  99  57  [212.162.9.150]
9    52  0  0.0  56  69  56  [195.122.154.3]
10    52  0  0.0  55  57  56  [159.100.232.171]
The last week trying to play ESO (EU) and getting EME type RTT from  xe-10-2-0.pcl-cr01.plus.net [212.159.0.200] on a regular basis
Re: xe-10-2-0.pcl-cr01.plus.net [212.159.0.200] - RTT nearer eme than 40ms
EME type RTT?
Gythral8PNC
Earth - moon - Earth
Your pings to the destination are fine though.
The pings along your route are irrelevant as long as the the end destination ping time is fine.
Edit: To explain further - see this https://www.nanog.org/meetings/nanog45/presentations/Sunday/RAS_traceroute_N45.pdf
Latency spikes in the middle of a traceroute mean absolutely nothing if they do not continue forward absolutely nothing if they do not continue forward.
  • At worst it could be the result of an asymmetric path.
  • But it is probably an artificial rate-limit or prioritization issue.
  • By definition, if regularly forwarded packets are being affected you should see the issue persist on all future hops.
