xbox one upnp fix
ghos7
xbox one upnp fix
i see alot of xbox one users complaining of having moderate or strict nat type even though they have enabled upnp on there router.the problem is if xbox one power mode is set to instant on then the xbox one upnp fails to work.changing xbox one power mode to energy saving will allow upnp to work.the xbox one has had this glitch since launch.
1 REPLY 1
legume
Re: xbox one upnp fix
Interesting, what router do you have?
Mine are all set to "off means off" so I haven't seen any problems myself.
Though it seems the one can't do IGD2 properly - which is especially silly as there are games like BO3 that need IGD2 features (though it should still work if you only have one xbox).
