xbox live problem
- Gaming
- Re: xbox live problem
xbox live problem
27-12-2010 10:54 PM
hi
for the last 3 day I heaving problem white xbox live
it all ways has work fine cant join live party or some games online
the ports are open and nat seems fine ? did a ping test that seed fine as well
any one els have this problem? hoop some one from pluse net can look into it
many thanks
many thanks
3 REPLIES 3
30-12-2010 9:32 AM
I've not been having any problems.
Your connection has dropped a few times over the last few days but nothing overly concerning:
Your on the correct traffic management profile as well.
Is your Xbox wired or wireless? If it's wireless, have you tried it wired to rule out wi-fi problems as a potential cause?
Session Ended Session Duration
N/A 18:20:8 (on going)
15:06 29/Dec/2010 0:59:52
14:05 29/Dec/2010 0:0:4
14:04 29/Dec/2010 0:6:50
13:39 29/Dec/2010 22:5:23
15:30 28/Dec/2010 2 Days, 0:36:53
14:53 26/Dec/2010 One Day, 0:30:52
13-01-2011 9:50 PM
i had that issue turns out my nat settings weren't correct you sure you are set to open not strict, and firewall/ ports are set to xbox live
http://portforward.com/
check this site out if you are struggling with ports
01-02-2011 9:05 PM
I'm a new Plusnet user and had exacly the same problem. I'm going to post my short but sweet answer to each of the 3 questions on this subject.
In short I joined Plusnet, had a problem with my X-Box, assumed it was Plusnet, phoned to cancel my contract to go to Sky, was offered a month free subscription but initially chose to cancel anyway.
I then had one last attempt and called my local computer repair company. He said it was not an unusual problem and spent 20 mins updating the settings on my Thompson router. It only cost £25 and now the X-box and 2 laptops (work and private) are working perfectly and have been for the last 2 months.
I called Plusnet and they honoured their 1 month free.
Hope this helps
Hope this helps
