xBox 360 wireless connection
- Gaming
- Re: xBox 360 wireless connection
30-03-2011 9:48 AM
Can anyone tell me whether we need a minimum speed from our connection before we can successfully connect XBox 360 via wireless adapter? We've tried everything including lengthy conversations with XBox and PlusNet; followed the set up guidelines on this site and still it wont connect.... PlusNet have confirmed that all ports are free from blockage; XBox recommended Portforward.com - but it looked pretty complex. We are struggling with speed at the minute with PlusNet claim to be investigating (we're back in a 10 day test period), and I've asked them to remove Interleaving from our line as I believe this affects on line gaming.... please can anyone offer advice? We've been with them a month now and we havent been able to connect successfully.
2 REPLIES 2
30-03-2011 10:30 AM
If you have a TG585V8 router (current PlusNet model), please try changing the wireless settings to b/g only, do not use the 'so-called n' on this router with an XBOX360 wireless (ESPECIALLY if the XBOX has a wifi n adapter).
Call me 'w23'
30-03-2011 8:25 PM
Excellent; cheers - it appears to have worked! 15 yr old son bouncing off the walls with glee
