wireshark a xbox or ps3
- Gaming
- wireshark a xbox or ps3
22-06-2013 12:52 PM
Is there a way to do this?
If not would you be able to do this on a pc with two ethernet cards. one connected to the internet and the other bridged with the console connected?
2 REPLIES 2
Re: wireshark a xbox or ps3
22-06-2013 1:25 PM
Hey there,
You certainly can do this,
Whilst I dig up the information on the port mirroring, can you confirm which router you're using? The TG585 or the 582? I believe the process is the same, but just to make sure I get you the right commands for the telnet session.
Cheers,
Matt
EDIT:
http://community.plus.net/forum/index.php/topic,108016.msg987868.html#msg987868 I believe this is what you want
Cheers,
Matt
EDIT:
23-06-2013 1:54 PM
I was just wondering. sorry I dont even own a console I just like to know how things work but this info is really help full. I dont see it anywhere on the forums.
