will the pro addon make online gaming better ?
matty2k13
hello, im on a 3.5mb connection and i get some bad lag online with ps4, just seen the pro addon may help. here is a speed test
look forward to hearing from you guys
3 REPLIES 3
AndyH
Re: will the pro addon make online gaming better ?
It won't make any difference - in fact, it can make things worse.
Have you raised a fault for your line? It looks like you might have interleaving on.
All4One
Do any other people use the connection in your house? Any specific times? Do you connect via ethernet? Helps to diagnose issues.
matty2k13
only me that uses it, i have told plusnet about it but they say everythink is fine, i will be getting fiber in a month or 2 so i can cope for now
