warframe port forwarding
- Gaming
- warframe port forwarding
03-12-2013 12:47 PM
Can someone help me to set up port forwarding with this on Tue technicolour router? I'm getting the message when I start the game that the nat is strict and that Upnp is malfunctioning and can I forward UDP ports 3960 and 3963 to 192.168.1.75.
I Checked in the router and upnp is enabled but I'm unsure about where to enter the port settings and does this just apply to warframe or do I have to enter separate port settings for different games?
Your help much appreciated
P.s.
Connection status on ps4 settings is showing nat type 2
P.s.
1 REPLY 1
Re: warframe port forwarding
03-12-2013 2:38 PM
i had same problems with cod ghosts with strict nat type tried everything, only when i used dmz it cured it........
