thompson 585 v7 portforward problem
- Gaming
- Re: thompson 585 v7 portforward problem
17-12-2009 5:03 PM
I checked my portforwarding on my router for my ps3 and the port profile i created was blank, so made another and that was blanked when i assigned it, as were the next 5 times i tried it. What is wrong with it? It creates them fine, i can view the port ranges , but the minute i assign it to my ps3 it gets wiped of the ports !! It's really bugging me now , so any help will be appreciated
2 REPLIES 2
17-12-2009 5:24 PM
Hi HaydnExport,
You need to:
1) Create the rule and save it.
2) DON'T ASSIGN IT. Create the same rule again.
3) Save the rule once more (it may prompt you to save it under a different name, this is fine).
That should sort it. Hope it does. Not sure why it behaves like that though.
You need to:
17-12-2009 6:45 PM
Oh man, thanks !!
It's been doing my head in
