still getting disconnected from BF3 pc
- Gaming
- still getting disconnected from BF3 pc
18-06-2013 9:26 PM
ive been getting this problem now for months and months which made me give up trying to play games online. after about an hour of playing i always get disconnected from the games server. is there a way i could monitor my pc to check what actually happens when i do get disconnected to see whats causing it. ive tried turning the firewall off but i still get the same. it cant be a fault with the game as there has been many updates for it and im still getting it.
8 REPLIES 8
Re: still getting disconnected from BF3 pc
18-06-2013 10:26 PM
have you looked at windows Event viewer ? > control panel > system & security > admin tools ?
but unless the game is crashing you wont see a lot,
1, is the game crashing or just losing connection , is connection fine while playing ? are you seeing a red triangle in top right had screen ?
2, Turn UPNP off on your router
3 , Update punkbuster
4,update hardware drivers .
last thing what are spec,s of your PC ie are you on minimum spec,s for game ?
a bit more info would help
PS bet Jim or strat moves this to gaming
19-06-2013 7:20 PM
thanx for the reply. the game doesnt crash at all. it just goes back to the server screen saying i was disconnected and i have to click on reconnect to the match. ive already tried with turning off upnp from last time i tried to sort the problem out. my pc spec is:
windows 7 64 bit
AMD phenon x4 955 processor 3.2ghz
4gig RAM
ATI radeon hd 5700 1 gig
ive also updated the driver for the graphics card and downloaded latest punkbuster. i only seem to be getting it while playing bf which is strange
windows 7 64 bit
4gig RAM
19-06-2013 7:30 PM
try this
Click on the windows logo/start button
-In the searchbar, type services.msc
-Press ENTER
-A list of services should now be in front of you.
-Click "extended" tab
-Search for "UPnP host devices" or something similiar (the description is something like: Allow hosting of UPnP devices blablabla)
-Right click it
-Click Properties
- there is an option "startup", in the general tab. You can choose between: Automatic (delayed startup), Automatic, Manually, Disabled. You must choose Disabled.
-Click on "stop service"
-Click "apply" and close that little windows.
-Search for "SSPD discovery" and do the same things that you did above.
-Close everything
-Reboot.
Ps is it just ranked servers you play on ?
-Press ENTER
-Right click it
-Click Properties
-Close everything
-Reboot.
19-06-2013 9:01 PM
ok ive done all that now so ill check it out. yes its mainly ranked servers but i just play for fun:P ill let you know how i get on. thanx:)
19-06-2013 9:24 PM
well it only lasted 25 mins then i got dc again:(
19-06-2013 9:47 PM
and again after 20 mins
19-06-2013 10:34 PM
A friend had a similar problem , EA support was poop
unfortunately the game when running is Ace
but so many bugs with Battlelog & silly Origin .
the only thing you
could try as a last resort is uninstall with Revo uninstaller , Game & origin , clean registry with C cleaner , then reinstall
i dont think its your connection it sounds like a BF Bug .
PS BF is the only game i play
the only thing you
20-06-2013 6:10 PM
seems like the only thing left to try really. i am tempted just to upgrade my graphics card and ram and do a clean install of evertyhing on the pc as its full of crap at the moment. whats your name on it ill give u an add
