slow gaming speed on plusnet hub
- Gaming
- Re: slow gaming speed on plusnet hub
16-09-2016 4:48 AM
16-09-2016 9:36 PM
i would raise a support ticket if its that low
16-09-2016 10:13 PM
19-09-2016 11:56 AM
So many problems with Xbox connectivity!
All the threads Ive seen on here a new router does seem to solve the problem (ive previously recommended Asus if you want a place to start looking).
That said, ultimately I think the issue lies with the xbox and that buying a new router is simply throwing technology at the problem. It does provide a quick fix mind.
19-09-2016 2:31 PM
25-09-2016 3:44 PM
So would changing the mtu from 1488 help, if so what should it be changed to as I'm in the same boat but on PS4
