ps3 performing issues
- Gaming
- ps3 performing issues
19-04-2013 8:32 AM
it keeps lagging on call of duty mw3 and the signal is crap keeps going dred and one bar the 3 green again and playstation network keeps cutting of and our connection is fine the guy said its not dropping the connection stable and has been 4 48 hours and i done speedtest 9 half meg download upload 0.34 latency 34 mis
3 REPLIES 3
Re: ps3 performing issues
19-04-2013 8:46 AM
The connection between the internet and the router is probably stable however the wireless connection between your router and PS3 maybe dropping or poor connection.
Try changing your wireless channel, this should hopefully improve the wireless connectivity
http://www.plus.net/support/broadband/hardware/technicolor-582n-wireless.shtml
Also the upload speed is important for gamers and if you are only getting 0.3mbps, this will probably mean that you have a capped upload speed. Get Plusnet to uncap your upload speed by raising a ticket or requesting this in the "Broadband and Routers" forum.
Hope this helps
Hope this helps
23-04-2013 10:43 AM
upload wont be important on mw3.
that amount of upload means he wont host a game which in fact is a massive plus point
23-04-2013 2:01 PM
Did you manage to try changing your wireless channel?
