ps3 nat type failed!
- Gaming
- ps3 nat type failed!
27-01-2009 9:40 PM
After problems with my old router i have now got a Dlink 2640b.It seems my luck has not changed and i still have connection issues.
The connection test on the PS3 says NAT Failed. I have tried DMZ but it still fails..
Could some kind sole please explain how to fix this .?
Re: ps3 nat type failed!
27-01-2009 9:47 PM
http://portforward.com/english/routers/port_forwarding/Dlink/DSL-2640B/PS3_NAT_Type_3_to_2.htm
27-01-2009 10:07 PM
i don't really know what these mean... also should using the DMZ have solved this?
It seems a common question on the web but i found no answers.
27-01-2009 10:17 PM
Can you use the browser or get to the PSN store?
27-01-2009 10:23 PM
Just the the online gaming parts not working..the connection Test check has everything available apart from NAT
27-01-2009 10:43 PM
Also do you have uPnP enabled on your router?
27-01-2009 10:47 PM
28-01-2009 1:19 PM
I put my router in DMZ and also my friends router in his DMZ. He eventually got NAT 2 but we STILL cant play each other on CoD5, stopped looking for the answer as no-one seems to know. Fifa was the same so i traded that in
'Unable to connect to Host'
28-01-2009 2:22 PM
Quote from: mrmarkus1981 I have same problem.
What firmware version were u using?
I have just tried an older version and it has come up with NAT 2 without using DMZ.
28-01-2009 2:26 PM
28-01-2009 2:35 PM
also routerstats lite works with this version and DMT tool as well..
