problems connecting to ps3
technojules
ok here is my status
my router is downstairs in hallway my ps3 is in back bedroom
i am using a dlink plug to connect my router to ps3 via ethranet through the house power cables
im using same setup to run internet on pc tower
everytime i log in to ps store i get the message " a connection to the network could be established error code 80130182
does anyone know how to sort it
(it has connected in past so i know all details are right)
1 REPLY 1
adamwalker
Fixes: 217
Re: problems connecting to ps3
I take it other web based apps or online games on your PS3 are connecting fine?
I'm not sure if the PC connects using the same poweline adapters, if not then I'd swap those over too.
Restoring the default settings on your PS3 will prompt you to set the network up again, so you may want to try that.
Adam
 Adam Walker
