plusnet gaming connection
- Gaming
- plusnet gaming connection
- « Previous
- Next »
Re: plusnet gaming connection
08-11-2007 9:09 PM
ill let you know how i get on.
08-11-2007 9:10 PM
09-11-2007 4:04 PM
my best one was a great improvement.--
Pinging www.bbc.net.uk [212.58.224.88] with 32 bytes of data:
Reply from 212.58.224.88: bytes=32 time=22ms TTL=248
Reply from 212.58.224.88: bytes=32 time=28ms TTL=248
Reply from 212.58.224.88: bytes=32 time=35ms TTL=248
Reply from 212.58.224.88: bytes=32 time=26ms TTL=248
Ping statistics for 212.58.224.88:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 22ms, Maximum = 35ms, Average = 27ms
on average im getting 30-35ms which is 15ms or so better. A good 30% or so better than b4.
Many thanks for sorting it out so quickly.
Im away to test it on the xbox now.
09-11-2007 7:00 PM
can you confirm my interleaving is off please
user name moz1974
hopefully i can blame my ping being "rubbish" rather than my FPS skills
ta
mike
09-11-2007 7:57 PM
From a quick line check (I'll post the results below just in case they're of interest) I can see that interleaving is set to 'Auto', which might as well be 'on'. Lay the blame on those lousy pings.
09-11-2007 10:40 PM
i put a request in a few weekes back to have it off, how do i go about getting it off? as i dont have the option any more on my control panel
ta
10-11-2007 3:29 PM
10-11-2007 9:11 PM
24-11-2007 7:59 PM
26-11-2007 1:18 PM
As per my other post, interleaving hadn't been removed at that point. I've since placed an order for you which should complete early tomorrow.
03-12-2007 4:47 PM
03-12-2007 5:23 PM
Unfortunately interleaving wasn't turned off, I've placed another order which should complete tomorrow morning. Sorry about the hassle there.
- « Previous
- Next »
