modern w2 signal strength
- Gaming
- Re: modern w2 signal strength
- « Previous
- Next »
25-11-2009 9:53 PM
by the way, IW are using the bars on PC too now because the actual figures are too shocking. 4 bars means 0-100, 3 means 100-200 ,2 means 200-300 and 1 bar is 300+. For anyone hwo doesn't know, the max playable ping is usually considered to be <100
28-11-2009 12:59 PM
riemanrez is that definite fact? Where did you read that, quite interesting because I play MW2 at the highest level you can in Europe and often my team has 3 bars. 200ms ping is shocking!!
28-11-2009 1:09 PM
its true, they are scammers and ill never buy a call of duty game again
you can edit the config to show numbers and the whole server is always 100+ latency apart from the host who is obviously 5ish
29-11-2009 2:29 AM
Hey stephen can you tell me how please, Id like to know this didnt know it was possible
30-11-2009 5:37 PM
Quote you can edit the config to show numbers
Hey StephenF can you explain how or link to somewhere that will?
So far i've only managed to edit the number of bars and interval, so that i have 10 bars with 20ms between. Numbers would be so much better though.
30-11-2009 9:30 PM
ok i found out how but you need the console hack to do it, and i don't plan on downloading that until i'm sure VAC can't detect and ban you for it. But it can be done, although it seems to reset when you close the game.
08-12-2009 1:42 PM
sorry my misunderstanding. you can only change the bar intervals, like you say, without the console you cannot get numbers. i just read wrong elsewere
- « Previous
- Next »
