lowest ping?
- Gaming
- lowest ping?
lowest ping?
09-07-2012 10:15 PM
What sort of things could be preventing me from achieving this?
I ask this because Im having big problems in online games and I aim to sort this problem even if it means upgrading to a more expensive provider. Im paying for the best service plusnet willing to provide me and Ive just been over charged again on my bill for the pro add, witch seems to have no affect on my line anyway.
Reply from 212.58.241.131: bytes=32 time=13ms TTL=245
Reply from 212.58.241.131: bytes=32 time=12ms TTL=245
Link Information
Uptime: 0 days, 6:57:47
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.208 / 21.011
Data Transferred (Sent/Received) [MB/MB]: 103,09 / 472,60
Output Power (Up/Down) [dBm]: 12,3 / 0,0
Line Attenuation (Up/Down) [dB]: 8,1 / 16,5
SN Margin (Up/Down) [dB]: 6,6 / 3,1
Loss of Link (Remote): -
Error Seconds (Local/Remote): 14 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 14
HEC Errors (Up/Down): 0 / 16
Re: lowest ping?
09-07-2012 10:21 PM
Re: lowest ping?
09-07-2012 10:54 PM
Re: lowest ping?
09-07-2012 11:22 PM
Quote from: Gus I would be glad of 12/13ms. I average 45 on a good day with my almost 2.5 mile phone line to the exchange.
its real easy you just move house closer to the exchange. In my case its in town but I'm willing to put up with this.
Re: lowest ping?
10-07-2012 7:01 AM
Re: lowest ping?
10-07-2012 7:03 AM
Re: lowest ping?
10-07-2012 7:15 AM
Can you point us at some examples of people with better than 8ms pings ?, are they in the UK on the BT network ?
Re: lowest ping?
10-07-2012 9:43 AM
The difference between that and 8ms is probably inconsequential. You'd need to be the best gamer in the world for it to make a difference. Or Spiderman!
Ex-Broadband Service Manager
Re: lowest ping?
10-07-2012 11:33 AM
I have seen faster (reliably reported) pings to bbc.co.uk from FTTC users but the difference, as Kelly says, is inconsequential. My own FTTC started at 7 to 8ms but has now increased to 14-15ms (DLM stabilising the line on 80/20).
Re: lowest ping?
10-07-2012 1:59 PM
I did used to play at a world wide rank lvl but that was some time ago and Id like to try again. and yes the smallest amount of lag could mean the difference between taking randon damage or not hitting the hit box. feeling to the way you move and lag can make it feel ruff and suttery. thats so off putting when your wanting to react without thinking about it. Aim without even trying, the mouse is an extension of me...
my point being, with fastpath I should get atleast 8ms to the best uk servers not 12.
In say bf3, a lot of my actions just dont register at all and when they do it seem at a big delay. Im having the sort of lag that will alow a player with half health to take a whole flip in the back without taking any damage thebn turn around and kill me for exp.
Im also getting 140ping in us server and not 75 like i used to 3 years ago on cable.
Ive read some BE users have as low as 5ms ping, is this because of the no network managment or next to none? I used to get 4ms ping to german servers 3 years ago on cable.
All Im trying to work out is will this ever be possible on my plusnet service so i can chase my dream again?
Re: lowest ping?
10-07-2012 2:28 PM
absolutely no offence taken
The shorter the distance between the user and the Plusnet gateways (London) the better the chance of an improved ping.
I certainly never saw anything less than 11 or 12ms on a line that was 100% known not to be interleaved when I was on ADSL(2+) (I typically saw 23 to 25ms when it was interleaved).
Cable (Virgin anyway) are often slated for massive lag during busy times, this may have been a lot better years ago with less congested networks.
FTTC is great if you can get it AND are close enough to the cabinet not to have enough line errors for the DLM to add latency.
Sorry I can't offer any more other than suggesting that you ask PN to confirm that BOTH downstream and upstream are fastpath as many routers don't report both.
Re: lowest ping?
10-07-2012 2:37 PM
Quote from: walker23 ask PN to confirm that BOTH downstream and upstream are fastpath as many routers don't report both.
it is interesting you say this because that would relate to the problems Im seeing on bf3. thou I seem to be receiving the information my actions are delayed.
Re: lowest ping?
10-07-2012 2:48 PM
Have a read here for more info:
http://gaming.stackexchange.com/questions/39343/is-lag-compensation-affecting-my-performance
and
http://en.wikipedia.org/wiki/Lag_(online_gaming)#Solutions_and_lag_compensation
Re: lowest ping?
10-07-2012 3:01 PM
The pings in your OP are good, more importantly they're consistent so stuttering and similar should not be happening.
Thinkbroadband's quality meter http://www.thinkbroadband.com/ping is an excellent tool for checking for latency issues but, again, DON'T run it while actually gaming competitively.
Re: lowest ping?
10-07-2012 3:29 PM
I just wont to know with PN is there a way I will see better than Im getting.
please dont try teaching me anything your unlikly to know any better your self.
at the end of the day there wouldnt be a better service if there wasnt a reason for it......
