last few month
callumx
last few month
For some reason i can't play online without red spikes on my lagometer  Undecided its been like this for 2 month and nothings changed. 1 second it will be fine, but mainly just red spikes. and internet running slow, even if i want to watch a video on youtube it takes a while to load up. 😕
anyone know what this could be?:S
thanks
15 REPLIES 15
Fixes: 1,483
Re: last few month
are you using a wireless or wired connection?
Can you post the results of a BT speedtest http://speedtester.bt.com/ and your router stats - might help to identify if you have issues or not.
callumx
Re: last few month
When i try do do a speedtest on speedtest.net it wont even load it just stops on 61 percent its going that slow, my ping is 76 to a 100 every time i try, it should be 30-40. and my download speed is 53 kbps, =/  how do i find my router status things? and i'll post that up.
avalon
Re: last few month
Or it could be exchange contention, have you checked here to see if there's any problems with your exchange?
callumx
Re: last few month
No i've checked, theres nothing wrong with my exchange, 😕
callumx
Re: last few month
Any staff online?
chillypenguin
Re: last few month
mod:note
Please can I ask you to take a few moments to red the link:rules on bumping threads.
zubel
Re: last few month
Try checking link:speed to see if there is a localised problem - perhaps you have suffered a low sync event and have a 135K profile, for example.
B.
callumx
Re: last few month
when i try to do a speedtest on that link you sent me it says theres an error.
scootie
Re: last few month
check here to see what PN have your line profiled athttps://portal.plus.net/my.html?action=data_transfer_speed  if thats o.k you need to check the bt speed test to see what your profile is with them http://speedtester.bt.com/
could do with some router stats. log into your router and post  your atten, snr , and sync speed
What router have you got and we can tell you how to login in to it.
most you log into by typing 192.164.0.1 or simlar into you browser address bar then admin for both username and password if you havent changed them
callumx
Re: last few month
Thanks guys for all your replys, i logged into my router. Is this the page you are looking for?
callumx
Re: last few month
http://www.speedtest.net/result/346098930.png
theres my result above^, it says my ping is good, but when i try to play a game online i just get loads of red spikes and crazy lag. and my download speed is messed up:S.
avalon
Re: last few month
The line stats don't look too bad,, what struck me though was that you had wireless enabled - but with no security.  If there's anyone living nearby they may be surfing the internet courtesy of your connectionwnl.  Wink
Oldjim
Resting Legend
Fixes: 63
Re: last few month
Strewth  - well spotted  Roll_eyes
Chris
Legend
Fixes: 169
Re: last few month
Looking at your account it seems that you hit the usage allowance for your account on Sunday (26th) which is why the speed on the test you have provided is so low. I'd definitely follow the advice posted by others to protect your wireless as it could be this that is causing your usage to go up.
You can buy more usage at £1 per GB or wait until your billing date in a couple of days when your speed will increase anyway.
Hope that helps.
