interleaving
whiteshadow
interleaving
  What happened to the option to be able to able to turn off interleaving?
  I had mine turned off a while ago but have since changed packages, will it have been turned back on again with the switch or will it just stay off? There doesn't appear to be any way to tell the status any more.
  Thanks.
5 REPLIES 5
Oldjim
Fixes: 63
Re: interleaving
Strat
Fixes: 565
Re: interleaving
I don't have that ability either...the link only taking me here https://portal.plus.net/my.html?action=myconnection
Oldjim
Fixes: 63
Re: interleaving
Guessing - I think that means that it is set to auto
whiteshadow
Re: interleaving
  Thanks for your responses guys, just came up with same for me too. I have put in a request with the support team to turn off interleaving anyway just in case.
scootie
Re: interleaving
changing package shouldn't effect your interleave status unless you have gone from ADSL to ADSL2+ or FTTC package change
what router are using, most but not all give the status of interleave away in the connection stats normally under interleave depth
