interleaving switched off
- Gaming
- Re: interleaving switched off
30-03-2010 8:04 PM
just wondered who to contact to turn it off ?
i do a spot of online gaming on a ps3 & usually join a game at 80 to 100 ms ping
my ping tests to london on the pc are about 84ms
do you think having interleaving turned off will improve gaming ?
cheers Bob.
30-03-2010 8:09 PM
30-03-2010 8:17 PM
am not to teccy how do i check if my line is stable ?
Cheers Bob
30-03-2010 8:20 PM
You can get help with getting your line stats with this link...http://www.kitz.co.uk/adsl/frogstats.php
30-03-2010 8:29 PM
router stats:
ADSL Link Downstream Upstream
Connection Speed 8128 kbps 448 kbps
Line Attenuation 4.0 db 2.0 db
Noise Margin 10.4 db 21.0 db
not sure about hec errors,fec errors etc ? but will google & try to find
Cheers bob.
30-03-2010 9:11 PM
30-03-2010 9:14 PM
here are some stats:
downstream rx
Noise Margin: 10.3 dB
Connection Rate: 8128 Kbps
Line Attenuation: 4.0 dB
Power: 7.8 dBm
Max Rate: 10016 Kbps
SF: 20736375
SF Errors: 33
Reed Solomon: 2820147064
RS Corrected: 3044
RS Un-Corrected: 1257
HEC: 32
Errored Seconds: 17
Severe ES: 0
Interleave Depth: 64
Bitswaps: 0
upstream tx
Noise Margin: 21.0 dB
Connection Rate: 448 Kbps
Line Attenuation: 2.0 dB
Power: 12.2 dBm
Max Rate: 1052 Kbps
SF: 20738432
SF Errors: 8
Reed Solomon: 352553344
RS Corrected: 30
RS Un-Corrected: 0
HEC: 4
Errored Seconds: 0
Severe ES: 0
Interleave Depth: 8
Bitswaps: 0
totals
Total Uptimes (From SF counts):
WAN: 4 days, 01:56:17
LAN: 4 days, 01:56:17
CRC: 33
LOS: 0
LOF: 0
ES : 17
Bytes Transferred (ppp0):
Tx: 170893802 (162.9 MiB)
Rx: 1672223038 (1.5 GiB)
IP address: 87.112.39.70
sorry for long post but am clueless now ? does it look O.K.
30-03-2010 9:23 PM
30-03-2010 9:27 PM
Cheers Bob.
30-03-2010 9:32 PM
This is how I got there
Help and Support http://www.plus.net/support/?helpheader=support
Help Assistant (second row of links)
My Broadband Connection
DSL Max Interleaving
30-03-2010 9:47 PM
Quote 8128 Kbps
how come there syncing at a fastpath rate but there error counts look as thoe interleaving is on
30-03-2010 9:57 PM
have sent a message to Help and Support requesting interleaving to be turned off
Cheers Bob.
30-03-2010 10:00 PM
30-03-2010 10:07 PM
Quote from: Asbo
Quote 8128 Kbps
Hi Asbo Dog,
Not sure what any of these numbers mean ?
they have allways been the same since my exchange was upgraded to 8mb 5 years ago
back then i could get that but its about 6.5-7.0 mb now on a speed test
but i can see the exchange from the back door
30-03-2010 10:13 PM
Quote It should also be pointed out that whilst BTw state that applying interleaving shouldn't reduce your line speed, it does reduce the maximum line rate achievable from 8128kbps to 7616kbps due to the additional overhead required for check bytes.
Note: although BT state 7616 is maximum sync speed with interleaving, many instances of higher sync speeds have been reported by users. This is dependent upon your router being able to support S=1/2 mode which effectively combines two RS code words into a larger logical code word of 510 bytes (ANSI T1.413).
And no - I don't understand it either
