iPlayer Judder on The PS3 - Is It Just Us ?
bobboulby
Would someone do me a favour and check out the program "Click" from Sat 31 October on the PS3 iPlayer.
On our 40Gb PS3 the image is juddering all the way through the program. I've check the same program on my PC (IE8 on XP) and it plays fine. A random sample of other programs on the PS3 are also ok.
I have noticed this juddering on the PS3 iPlayer before but it only seems to affect the odd program.
I was wondering if it was just us?
Thanks - Bob
Edit - just to be clear, it's not buffering but stuttering as if there isn't enough processing power to play the image smoothly.
22 REPLIES 22
Fixes: 1,481
Re: iPlayer Judder on The PS3 - Is It Just Us ?
I'll have a check shortly, Waterloo Road played fine earlier on.
Strat
Fixes: 565
Just checked and yes it's juddering from the start. Sound is fine but picture is juddering.
Also checked it on PC and yes it's fine there too.
bobboulby
Thanks Strat, it's reassuring to know that it's not just us then. As I said I've noticed it a few times, hopefully Sony are aware and will get it sorted.
Bob
Fixes: 1,481
Not just you Bob, same thing here on an original 60GB PS3
Strat
Fixes: 565
I've watched other programs on iPlayer on the pS3 before and also haven't noticed a problem.....admittedly very few as I've only recently bought my PS3.
120GB Slim model BTW.
Fixes: 1,481
We've watched a fair few and never seen anything like it. Does seem very odd to be just one program.
Euge
I was going to come straight in with the answer but it's not the problem I thought it was.
I'll tell you this little tidbit anyway. If you replace the hard drive for a bigger hard drive do your research because some of them seem to cause a slight pause every 10 seconds when watching bbc iplayer. I assume it's to do with read/write speed or some such technical problem I don't really know.
As for this irregular one I haven't got the foggiest.
Strat
Fixes: 565
I've asked the BBC the question so we'll see what they have to say....if anything.
Probably something like 'update your software / firmware'.
bobboulby
We use the iPlayer on our PS3 quite a lot and I'd say that I've seen this problem 2 or 3 times. We've not replaced our HDD and are on the latest version of the firmware.
It will be interesting to see what the BBC say.
Bob
Strat
Fixes: 565
My PS3 is the latest model with the latest firmware.
Strat
Fixes: 565
Update.
I have received a reply from the BBC and you may not be surprised at the contents.
Thank you for contacting BBC iPlayer support team.
I understand you are experiencing problems streaming programmes on PS3.
I would advise that you first clear your cache and cookies within the PS3 browser:
From the main menu, select Network.
Select Internet Browser.
After the Internet Browser appears press the Triangle button.
Select Tools on the Options menu.
Select Delete Cookies or Delete Cache then select Yes to confirm.
You will then need to ensure that you have the most recent firmware available for the PS3.
Once again thank you for contacting BBC iPlayer.
Regards
[removed]
Bearing in mind that I specifically stated that the problem affected Click and no other program I had tried, that's a pretty standard CSA reply...abbeit from the BBC. Roll_eyes
Fixes: 1,481
and they fail to realise you can't get online without the latest firmware...
Strat
Fixes: 565
I would probably have got a better answer from Jameseh Wink
Mand
Re:iPlayer Judder on The PS3 - Is It Just Us ?
Nah, from Jameseh you'd have been told to get an XBOX :p, BBC iPlayer clearly don't have a Comms Team though Wink
I've had problems with Click on the standard iPlayer before, strange that it would only affect that on the PS3.
