how to check if interleaving is off or on?
- Gaming
- how to check if interleaving is off or on?
- « Previous
- 1
- 2
- Next »
Re: how to check if interleaving is off or on?
25-03-2010 10:47 AM
That sounds absolutely fine for gaming Mandoo.
25-03-2010 12:20 PM
the lower the better mandoo, the higher the number the more lag you will get in games, but with those sort of pings you have with plusnet you should be more than fine:)
- « Previous
- 1
- 2
- Next »
