how to check if interleaving is off or on?
nittygritty
hi, is there a way to check for myself if interleaving is turned off or on, and if its switched off does it improve pings? not that i have a problem as of yet, but just wondering if by switching it off it will improve my pings even further,
16 REPLIES 16
scootie
Re: how to check if interleaving is off or on?
what router do you have? most will tell you. this is what i get from my zyxel through telnet
P-660HW-T1v3
7wan adsl chandata
77777777777777777DSL standard: ADSL_G.dmt
near-end interleaved channel bit rate: 1952 kbps
near-end fast channel bit rate: 0 kbps
far-end interleaved channel bit rate: 448 kbps
far-end fast channel bit rate: 0 kbps
if running windows run a cmd promt tracert to bbc.co.uk
these are my interleved pings over a post office connection. on my PN fast path line i got 16-20ms from derbyshire. the nearer to london (pn's gateways) the lower your ping should be
C:\Users\SparrowHawk>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.224.138]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  192.168.1.1
  2    27 ms    26 ms    26 ms  217.47.109.250
  3    26 ms    26 ms    26 ms  217.47.109.161
  4    25 ms    27 ms    25 ms  217.47.204.10
  5    26 ms    25 ms    27 ms  217.47.251.241
  6    26 ms    25 ms    26 ms  core1-pos12-1.manchester.ukcore.bt.net [194.72.2.241]
  7    30 ms    31 ms    31 ms  core3-pos0-1-5-0.ealing.ukcore.bt.net [62.6.204.193]
  8    32 ms    31 ms    31 ms  core1-pos5-0-0.telehouse.ukcore.bt.net [194.74.65.122]
  9    34 ms  203 ms  212 ms  194.74.65.42
10    31 ms    32 ms    34 ms  212.58.238.153
11    32 ms    31 ms    31 ms  virtual-vip.thdo.bbc.co.uk [212.58.224.138]
nittygritty
mines a D Link DSL-2640R
scootie
try this http://www.kitz.co.uk/adsl/frogstats.php#52
if you havent requested fastpath then the DLM would be set to auto which in most cases means interleved
Chris
Legend
Fixes: 169
Asbo's got it spot on. Your line is set to 'auto' for interleaving and it's currently running in interleaved mode. If your connection is stable without any drops then we can place an order to remove interleaving if you like? It takes 24 hours to complete and we can always turn it back on if required.
nittygritty
heres what i see
Mode: G.DMT
Type: ANNEX_A
Status: Showtime
  Downstream Upstream
Rate (Kbps): 6656 kbps 448 kbps
SNR Margin (dB): 17.0  25.0
Attenuation (dB): 12.5  4.5
Output Power (dBm): 14.0  12.5
Super Frames: 399792 399791
RS Correctable Errors: 5 0
RS Uncorrectable Errors: 0 0
HEC Errors: 0 0
Total Cells: 63147 62803
Data Cells: 1046208 193875
Bit Errors: 0 0
is that good or bad lol
nittygritty
 1     1 ms    <1 ms     1 ms  192.168.1.1
 2    35 ms    36 ms    38 ms  lo0-plusnet.pcl-ag01.plus.net [195.166.128.27]
 3    37 ms    37 ms    34 ms  gi1-2-803.pcl-gw1.plus.net [84.92.5.57]
 4    35 ms    34 ms    34 ms  te2-1.pcl-gw02.plus.net [212.159.1.114]
 5    38 ms    35 ms    34 ms  te2-2.thn-gw2.plus.net [212.159.0.190]
 6    42 ms    37 ms    34 ms  rt0.thdo.bbc.co.uk [212.58.239.25]
 7   190 ms   203 ms   198 ms  212.58.238.133
 8    34 ms    35 ms    35 ms  virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
this is the tracert from bbc.co.uk
so would turning my interleaving off improve my pings? if so i would like to turn it off and see how it goes for a while, also if i wanted to turn it back on i assume it takes the same time to turn back on as it does to turn off?
Chris
Legend
Fixes: 169
You'll probably see a slight reduction in pings when it's off yes. Turning it back on is the same as turning it off, the order goes through on the next working day.
I'll go place the order now to remove it for you.
nittygritty
thanks chris, do you need my account number or anything?
paulpicks21
Chris , assuming mine is switched on at the moment can I also put in a request to have it turned off to try it out?
My connection seems rock solid at the moment so I would imagine it to be ok.
Cheers.
Chris
Legend
Fixes: 169
Nope, I can get to your account via the username you've registered on here.
I'll go take a look.
paulpicks21
Thanks again for the PM Chris , will report back tomorrow on this thread to see if there is any difference  Smiley
paulpicks21
Wow , its certainly made a difference!
I ran some pings yesterday to a few sites and have ran the same this morning
to yahoo.co.uk  ping is down by 20
to google.com down by 20 again
to metcheck.co.uk my ping is only 17!
On the Cod4 server I play on (usa one) the ping is down by about 40!
And on pingtest.net its much lower than I have seen before.
So overall very happy so far  Smiley
nittygritty
C:\Documents and Settings\paul>tracert bbc.co.uk
  1    1 ms    <1 ms    <1 ms  192.168.1.1
  2    17 ms    17 ms    18 ms  lo0-central1.pcl-ag04.plus.net [195.166.128.241]
  3    16 ms    16 ms    16 ms  gi1-10-411.pcl-gw01.plus.net [84.92.6.224]
  4    16 ms    15 ms    17 ms  te2-1.pcl-gw02.plus.net [212.159.1.114]
  5    16 ms    16 ms    16 ms  te2-2.thn-gw2.plus.net [212.159.0.190]
  6    18 ms    18 ms    16 ms  rt0.thdo.bbc.co.uk [212.58.239.25]
  7    17 ms    16 ms    17 ms  212.58.238.149
  8    17 ms    18 ms    19 ms  virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
just done tracert looks much better compared to yesterday bbc test
cheers chris will keep tabs over the next few days incase owt changes
Mandoo
Just out of interest, what sort of ping should I be getting to have a suitable gaming connection?
I'm sure my connection is fine, but I'm curious to know the numbers a little. My old VM connection was always around 35-40, and so far Plusnet its been between 25-30.
