high ping with plusnet..........low ping with talk talk
- Gaming
- Re: high ping with plusnet..........low ping with ...
13-06-2013 6:47 PM
Re: high ping with plusnet..........low ping with talk talk
24-06-2013 10:54 AM
24-06-2013 11:12 AM
29-06-2013 10:07 PM
would like to know how yours is getting fixed please!!!!
29-06-2013 11:40 PM
I've popped a response over to you at: http://community.plus.net/forum/index.php/topic,116215.msg1003279.html#msg1003279
01-07-2013 1:22 PM
Whilst Chris's info is important to test for nicnicnic (although his problem is more that he just has slow speeds, rather then soley high ping), if the line and equipment (maybe other than using the Plusnet router are unchanged) then it's hard to understand why the service isn't similar and may be a reason for all the gaming ping issues we have being seeing on Plusnet as of late.
Chris do you have more info other than testing equipment?
01-07-2013 6:14 PM
02-07-2013 10:50 AM
Ex-Broadband Service Manager
02-07-2013 8:59 PM
03-07-2013 10:18 AM
Quote The man said at the time there was something on my line restricting my ping. He took it off and after a day or so my ping was as i said awesome. Can i have it back please?
This is interleaving (a form of error correction). When it's turned on it increases pings slightly due to the additional error correction ongoing, this was turned off for you and remains off (although we're double checking that).
Quote im paying an extra £5 for this
That sounds like the Pro add-on, which really shouldn't be needed on Unlimited. In fact if you're using your line heavily while gaming too, Pro can actually have an adverse affect as it gives all traffic a high priority.
03-07-2013 11:33 AM
Are you able to run speed test/ping test on another device to see if you get any different results?
03-07-2013 11:38 AM
http://community.plus.net/forum/index.php/topic,115437.msg995313.html#msg995313
03-07-2013 1:55 PM
04-07-2013 9:19 AM
- Gaming
