gaming on plusnet why is it so slow
- Gaming
- gaming on plusnet why is it so slow
01-11-2011 9:53 PM
Re: gaming on plusnet why is it so slow
01-11-2011 9:59 PM
A BT speed test would be useful as would the current line speed from https://portal.plus.net/my.html?action=data_transfer_speed
01-11-2011 10:04 PM
http://www.plus.net/support/broadband/hardware/thomson-585-faqs-and-troubleshooting.shtml
line stats, connection speed, snr, attention (both up,down)
would be helpful to set a ttb ping monitor up, only your router needs to be on and respond to pings on wan set up on router if its not all ready.
http://www.thinkbroadband.com/ping/share/88d6556776027a75001ac5e45413b280.html
if the tbb pings dont show any major increases during the insane periods with pc an gaming running then its going to be a router lan side issue, if tbb shows same insane periods then maxing upload download is likely
02-11-2011 12:29 AM
02-11-2011 8:29 AM
02-11-2011 2:25 PM
02-11-2011 5:27 PM
I'm sure I can get this sorted for you. Are you using any extension cables/sockets before the router. Could you plug into the test socket so I could run some tests? Your SNR is quite high at the moment so if we could get your line set up better I could probably make your speed much higher than the current 2000k
Jojo
02-11-2011 8:16 PM
03-11-2011 3:13 PM
what is happening is than when i am online in a game say mw2 i get a lot of lag and ts keeps dropping out plus if anyone else uses the internet at all it just slows right down to a crawl any help would be appreciated i have just finished the first ten days and it not getting any better sad face
03-11-2011 3:23 PM
one thing i can say that plusnets customer sevices are the best by far that i have ever deat with
04-11-2011 5:48 PM
04-11-2011 9:15 PM
07-11-2011 9:57 AM
Quote from: rodtrotter hi yes i do use a extension cables/sockets before the router
Extension cables are notorious for causing trouble. I'd be interested to know the results via the test socket.
Jojo
07-11-2011 10:39 AM
Regarding the settings, it should be fine with standard settings (PPPoA, VPI/VCI 0 and 38 respectively) - just make sure you've put in your username and realm (whatever you log into the portal with, with @plusdsl.net on the end for the realm) and your account password and it should work fine.
There's more detail on our website here: http://www.plus.net/support/broadband/help_and_setup/connections_settings.shtml
