fut champions lag
fut champions lag
playing fut champions on fifa 17 is impossible because every game has serious lag and when your lagging its near enough impossible to perform skill moves. fut champs is played on dedicated servers so connection should be good. ive set up port forwarding but its not helped. can someone at plusnet check my connection.
13 REPLIES 13
Re: fut champions lag
after all this time still no fix. game still unplayable. i think the problem  is at plusnet end as my mate  who is with a different isp and he can play lag free.
Fixes: 9
Who is your friend with?
Kelly Dorset
Broadband Service Manager
Fixes: 9
Are you able to see server addresses of where the games are hosted?
Kelly Dorset
hi kelly, is there a way i can find out?
i asked 2 of my friends and 1 is with bt and the other is with sky. other games are fine its just fut champs.
Fixes: 9
Not sure about that.  Best way would be a wireshark while you are gaming, but I was hoping you could see in the interface or something.
Is there any pattern to the lag?  Only in the evenings, anytime at all, sometimes fine,  then not?
Kelly Dorset
Fixes: 9
Also, do you notice any issues with other games? Or is it just FUT?
Kelly Dorset
Fixes: 9
It looks like the servers are at "easo.ea.com" but a wireshark or (netstat from your machine if you are on a windows machine) while connected should confirm it.     traffic to that address is going through a DDOS protection company which might explain it.
Get your friends to traceroute to easo.ea.com and see if it goes the same route through prolexic.com?
Kelly Dorset
This is the trace route for Fifa 17
im changing isp enough is enough.
Fixes: 953
Sorry to hear you're having issues, and are thinking of leaving us.
Testing your broadband connection isn't really identifying any problems.
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 79.9 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 355.3
Upstream Rate Assessment Very Good
Technology VDSL
Profile Name 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Do you notice the lag using other games?
Are you also using a wired or wireless connection?
Fixes: 9
Was that your trace or did you ask your friend without the problems to do one?
Kelly Dorset
Fixes: 9
Our current thinking is that this is down to Prolexic who are doing DDOS filtering for FIFA:
Similar from last year: https://community.talktalk.co.uk/t5/Fibre-Broadband/New-38mb-net-fifa-delay-problem/td-p/1578196
Kelly Dorset
