fifa 14 lag on ps4
matty2k13
fifa 14 lag on ps4
Can anyone tell me why im getting lag on everygame of fifa I play. Dont try and tell me its ea's end because my mate next door is with bt and he gets no lag at all so I need this sorted or I will have to be moving isp
10 REPLIES 10
AndyH
Re: fifa 14 lag on ps4
ADSL or Fibre? Wired or wireless?
Can you post your router stats (if you're on ADSL)?
Pettitto
Fixes: 5
Hi matty2k13,
I've taken a look at your line and I can see a couple of things which might be causing lag on Fifa 14.
Your line is <a href="http://community.plus.net/library/broadband/broadband-faults-guide-banding-guide/">Banded</a> which may be restricting the speeds you can receive. The banding may be in place due to your connection being unstable historically.
That said, even with banding in place, your line quality isn't looking great, are you able to connect your router into your Test Socket with an alternative microfilter?
matty2k13
DSL Connection
Link Information
Uptime:2 days, 23:29:34DSL Type:ITU-T G.992.3Bandwidth (Up/Down) [kbps/kbps]:995 / 4,235Data Transferred (Sent/Received) [MB/GB]:249.43 / 1.18Output Power (Up/Down) [dBm]:12.6 / 0.0Line Attenuation (Up/Down) [dB]:31.1 / 52.0SN Margin (Up/Down) [dB]:5.5 / 6.2System Vendor ID (Local/Remote):TMMB / ----Chipset Vendor ID (Local/Remote):BDCM / IFTNLoss of Framing (Local/Remote):0 / 0Loss of Signal (Local/Remote):0 / 0Loss of Power (Local/Remote):0 / 0Loss of Link (Remote):-Error Seconds (Local/Remote):5,122 / 0FEC Errors (Up/Down):0 / 0CRC Errors (Up/Down):1,168 / 35,613HEC Errors (Up/Down):670 / 10,798
Its a wired connection aswell
matty2k13
Its in the test socket
Pettitto
Fixes: 5
Can you swap the microfilter over for an alternative too?
matty2k13
New filter 2days ago
matty2k13
What can you do to sort it out and how long will it take
matty2k13
I need this sorted out as soon as possible.  Cry
Chris
Legend
Fixes: 169
You'll need to run through the faults checker now at faults.plus.net so our team here can take a look in more detail.
matty2k13
Ok thanks chris ill do that when I get home from work
