fifa 14 lag on ps4
- Gaming
- Re: fifa 14 lag on ps4
fifa 14 lag on ps4
14-04-2014 5:09 PM
14-04-2014 5:14 PM
Can you post your router stats (if you're on ADSL)?
14-04-2014 5:18 PM
I've taken a look at your line and I can see a couple of things which might be causing lag on Fifa 14.
Your line is <a href="http://community.plus.net/library/broadband/broadband-faults-guide-banding-guide/">Banded</a> which may be restricting the speeds you can receive. The banding may be in place due to your connection being unstable historically.
That said, even with banding in place, your line quality isn't looking great, are you able to connect your router into your Test Socket with an alternative microfilter?
14-04-2014 5:20 PM
DSL Connection
Link Information
Uptime:2 days, 23:29:34DSL Type:ITU-T G.992.3Bandwidth (Up/Down) [kbps/kbps]:995 / 4,235Data Transferred (Sent/Received) [MB/GB]:249.43 / 1.18Output Power (Up/Down) [dBm]:12.6 / 0.0Line Attenuation (Up/Down) [dB]:31.1 / 52.0SN Margin (Up/Down) [dB]:5.5 / 6.2System Vendor ID (Local/Remote):TMMB / ----Chipset Vendor ID (Local/Remote):BDCM / IFTNLoss of Framing (Local/Remote):0 / 0Loss of Signal (Local/Remote):0 / 0Loss of Power (Local/Remote):0 / 0Loss of Link (Remote):-Error Seconds (Local/Remote):5,122 / 0FEC Errors (Up/Down):0 / 0CRC Errors (Up/Down):1,168 / 35,613HEC Errors (Up/Down):670 / 10,798
Its a wired connection aswell
14-04-2014 5:22 PM
14-04-2014 5:29 PM
14-04-2014 5:37 PM
14-04-2014 6:49 PM
15-04-2014 1:31 PM
15-04-2014 1:33 PM
15-04-2014 1:34 PM
