fast track same as interleaving off?
max99
high guys, recently signed up with plusnet pro and wanted to check i was getting the lowest pings available.  the guy on techy support said i was already on 'fast track' and that all pro customers are automatically put om that.
does this mean my interleaving is off?
if i ping bbc.co.uk i get around 48ms although i live in the far north of scotland.
scootie
Re: fast track same as interleaving off?
sure they didnt say fastpath?
48ms from north of scotland is possablely fastpath.
what router do you have, most will report the interleaving status
tells me on my dg834g v4 netgear by using routers telnet info, channel: fast
# /usr/sbin/adslctl info --stats
/usr/sbin/adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 8000
Channel: FAST, Upstream rate = 856 Kbps, Downstream rate = 3683 Kbps
Link Power State: L0
Mode:                   ADSL2
Channel:                Fast
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
               Down            Up
SNR (dB):       11.4            4.5
Attn(dB):       50.0            28.2
Pwr(dBm):       0.0             12.5
Max(Kbps):      4116            840
Rate (Kbps):    3683            856
max99
hey man, they probably did say fastpath.  i guess that's the same as interleaving off then?
my router is the thomson one plusnet supplied.  it dosen't seem to report that stat.
thanks
scootie
yep interleaving off is normaly reported as fastpath http://www.kitz.co.uk/adsl/interleaving.htm
you may have to telnet into it using this command here http://community.plus.net/forum/index.php/topic,80792.msg659208.html#msg659208
HaydnExport
Great!!  just been able to check mine , thanks asbo
